Almost giving up on 07 LR3...help
Old Dec 20, 2024 | 07:13 AM
Sweden LR3 owner's Avatar
5th Gear
Default LR3 Alternator
So alt com duty cycle is checked and the ECM is out putting 40% duty cycle, 4,95 Volts measured at the alternator ( a little low, but due to resistance in wires i guess its okay) this should output 13,4 Volts, but only 12,1 volts measured at battery posts. A little corrosion found on the frame ground post, but no resistance can be measured but will clean anyway. Next is to check the error state if it will output 13,8Volts with connector unplugged.
Old Dec 20, 2024 | 07:37 AM
5th Gear
Three pin connector has now been unplugged and engine started. No Voltage output from alternator, so the brand new bosch alternator is pronounced dead. Ill update when new denso alternator is installed. What killed the bosh generator i think is the high voltage in start up wich appears to be too much for the rectifier maybe its connected with the AGM battery. It seems that the OEM is designed to handle these high peaks.
Old Dec 20, 2024 | 12:47 PM
Rufflyer's Avatar
Default A few thoughts
Originally Posted by mrossipir
update
Installed new starter, checked and cleaned starter cable from battery. Purchased new ECM and had it cloned. Replaced alternator with OEM. Problem still there
kels83 i will check the radiator fan plug to make sure no separated terminals. I have a single battery, same one I have always used it 1000 CCA since i am also running a 12k lb winch. Battery is new also voltage 12.7v.
I will also check the alternator wire although the alternator fuse in the fusebox is working properly.
Did you replace the ground wire from the body to the battery? (the one that goes back up under the fender).
We know that a bad alternator will make the cooling fan run non-stop, but you may want to look at the coolant temp sensor as it also controls the cooling fan. Are you having any HVAC issues? Do the temp ***** make the air hot and cold? HVAC affects the cooling fan as well.
Also the voltage spike may be an effort on the alternators part to charge the battery, and with a bad ground cable well....... it won't operate as expected.
Hope this helps
Jeff
Snafu / Disco Fries
Dec 7, 2022 07:46 AM
JHLR3
Jul 22, 2020 02:43 PM
PNWdisco
May 8, 2017 08:44 PM
Rover De Land
Aug 28, 2012 07:54 PM
iplayblues4u
Jan 10, 2012 05:27 PM
