Ambient Air Temp. Sensor location.
Old 09-18-2020 | 04:32 PM
Wrench's Avatar
Default Ambient Air Temp. Sensor location.
I am officially stuck...
2006 LR3 4.4
Got a P0071 code and picked up a replacement sensor from a local dealer...
Figured I'd replace it, clear the code and wait to see if it corrected. My shop manual
line drawing is...vague...at best. And for the life of me I can not locate where Land Rover put this thing.
I know it's behind the grill (which is off), and in front of the radiator. I got nothing, ugh
Can anyone please get me close. I really would appreciate it. Thank very much!!
Jim
Old 09-18-2020 | 08:55 PM
DakotaTravler's Avatar
I dont recall it being behind the grille, thought it was behind the bumper on the passenger side.
Old 09-18-2020 | 09:37 PM
Wrench's Avatar
Thanks, I'll take a look in the morning.
Old 09-19-2020 | 09:40 PM
Globetrotter448's Avatar
This is what you are looking for (Famous Four image)
Old 09-20-2020 | 06:46 AM
Wrench's Avatar
Yes, thanks. That is the part for sure I just can't find it's location in the vehicle. Removing the front skid plate (again) this morning. Taking a look around the passenger side behind the bumper.
Old 09-20-2020 | 01:37 PM
azlandy1's Avatar
Default Ambient temp sensor
Did mine. Took off the central grill and then the plastic deflector plate on top of the bumper cover It was dangling There Bit right but you’ll find it. Mine was damaged by rodents so a rewire and a new location (zip tie to the rescue) and back in business. FYI it seems to take a few hours to accurately reset the temp in the dash display so don’t think you did it wrong straight away!
Old 09-20-2020 | 03:40 PM
Wrench's Avatar
I'm in Paradise Valley or better known as Pack rat/Roof rat City. I "think" a previous owner installed a generic sensor behind the grill in front of the radiator. Just sort of dangling there. Just favoring the drivers side of center. Pulling my hair out for such a simple problem.....
Old 09-20-2020 | 06:32 PM
azlandy1's Avatar
Default Sounds similar
Mine is zip tied to the front frame rail and works fine. Rats ate the mounting bracket but it works fine there
Old 09-24-2020 | 10:44 AM
Wrench's Avatar
Finally. I could NOT find the sensor because it was "removed" by a pack rat. My Rover guy eventually found "a wire" behind the bumper. Spliced in a new sensor and all is right with the world. What a pain in the ***.
morrisdl (09-24-2020)
Old 09-24-2020 | 11:25 AM
azlandy1's Avatar
exactly my situation. Unfortunately north Scottsdale landrover charged me $500 for the Insight ! Now I know !
Wrench (09-24-2020)
ssblast20
Range Rover L322 (3rd Gen)
02-02-2019 12:54 PM
atancreti
09-23-2016 10:01 PM
pgoodrich
08-19-2015 08:31 PM
vjm530
12-19-2007 11:36 AM
apcollin
12-05-2007 09:53 PM
Quick Reply: Ambient Air Temp. Sensor location.
