any tricks to unscrew downstream 02 sensor?
Old Oct 6, 2018 | 09:26 PM
DakotaTravler's Avatar
They are not identical at all, look close. With that said, they probably operate the same if installation wont interfere and it can still be plugged in.
Old Oct 7, 2018 | 04:46 PM
searover83's Avatar
Hi.. and thanks for your support.. so turns out the O2 sensors are ok, just had a missing fuse in the feed circuit. .prob my fault. .duh.
I still get the EGR code P0406 - circuit A high.. and now get P2099 and P2097 .. downstream O2 sensors showing rich trim..
I guess the EGR..
what say you?
Old Oct 7, 2018 | 06:00 PM
So you may have. had two issues. Odd the downstream show a code but not the upstream O2 sensors. The upstream should be more sensitive, so to speak. Are you sure the EGR valve is getting power when it should (also not missing a fuse)?
Old Oct 8, 2018 | 02:19 PM
searover83's Avatar
ha. yes good point.. didnt tell you the important part.. glad you asked. The 'EGR command' reading on the iCarsoft was always 0 while driving.. and "EGR error" was 50-99%.. depending on throttle position.. (not sure how error is defined) . So you are spot on.. sounds like it's not getting the signal to open.. Need to find the pinout for the connector.. but how would I test it under proper conditions..? Would be lucky if its a bad or missing fuse..
Old Oct 8, 2018 | 05:01 PM
The EGR valve should be fully closed by default (engine off, etc). And it does not operate at all RPM. So the 0 when driving might be normal. I can not say for sure as EGR systems are one thing I never really had to dig into - which also means I have no clue how that error translates either.
Old Oct 23, 2018 | 09:48 PM
searover83's Avatar
update.. On a 2005 LR3 4.0 v6... so I did get the EGV1055 EGR valve, instead of the 1178, and they are different, but only in orientation of the top half, containing the sensor modules. I fixed the orientation, instead of making adjustments to the wiring and vacuum lines.. which was the other option.. anyway.. saved a bill with 10 mins of work. The EGR code that I had, P0406 . .'egr circuit A sensor high' cleared, and no CEL!! for the first 20 minute test ride. The next drive .. CEL comes on.. in 3 mins .. F*k.
Now I get P2097 .. Post Catalyst fuel trim system too rich. need to check what the sensor is outputting.. Will look for leaking/clogged exhaust or O2 sensor or wiring.. Any other ideas/comments?
TIA
Scott_C
Jan 17, 2019 10:31 AM
redwhitekat
Apr 20, 2018 07:01 PM
kcJohn703
Jun 15, 2013 11:45 AM
oilspotLR
Jul 24, 2012 11:05 PM
Kalel
Jun 1, 2012 07:06 PM
