Automatic stuck in park
There are a number of sensors in the console. Could be that one that is connected to the transmission got wet. You could get into the console and try to dry them out and see if that helps.
I left the sun roof open and got some rain on the console of my LR3 and it showed a suspension fault until it dried out.
Sam, I'm sorry but I am not sure on your truck... I assume it is similar to mine but I have a Discovery II. On mine you pull the shift **** straight up with some muscle and it pops off (by design). You then carefully pull up the gear selector cover on the console... it makes clicks as you pull it up, and tilts back, coming off. The switch is to the right next to the gear selector and removing it (if memory serves) is just a couple of screws and the wiring connector, which pinches off.
The quick fix to get on the road is to do all of that and just slide the pin back manually. That should free your gear selector.
Good luck.
