Bad parts quality
Old May 16, 2018 | 10:07 AM
TOM R's Avatar
Default Bad parts quality
So today i had to reppace the alternator again lasted 3 years which i guess is ok, but the brand new all makes belt i installed 6 months ago and about 6k miles is already cracked and looks oike it needs to be replaced see pic, thats realy **** quality imo
Old May 16, 2018 | 10:41 AM
OverRover's Avatar
That's total B$, but I can't say that I'm shocked seeing another Allmakes part that is a POS
They use the cheapest Made in China type vendors and slap the Allmakes name on it = NO THANKS!
If you want a belt that will last get a GATES. I've used Gates Belts on ALL my cars/trucks for years with zero issues.
And a headsup if you don't want to order one online, you can get Gates Belts at any NAPA.
They use Gates as their "private label" brand ( part numbers will start NBH...).
Old May 16, 2018 | 11:14 AM
Friday Night Disco's Avatar
I had an issue with the serpentine belt after 300 miles. I left negative feedback on Amazon and will never purchase allmakes product again
Old May 16, 2018 | 12:38 PM
mirrajumper's Avatar
You have to be careful. Terrafirma /all makes is hit/miss with quality. Suspension stuff ships with no hardware and the rubber items don’t fit well. If the parts hold fluid or are a safety concern- there are other vendors that better quality than the China sourced stuff. Often times the real OEM stuff is on sale and is a better fit when installed.
Keep shopping and find the price and quality that works for you.
Old May 16, 2018 | 01:54 PM
DavC's Avatar
For belts, serpentine, V belt, timing belts, etc.
use DAYCO. They aren't even expensive.
Old May 16, 2018 | 09:29 PM
TOM R's Avatar
Last belt was a goodyear gatorback which i have never had issues with, on lr3 it shreded in under 100 miles and left us stranded
Old May 18, 2018 | 06:01 PM
DakotaTravler's Avatar
^ Sounds like a bad install. No belt should fail that quick unless it was ridding on a pulley wrong.
Old May 19, 2018 | 06:22 AM
JUKE179r's Avatar
I had the Continental (?) Gatorback that some people swore was the best belt For a Disco 2. At 200 miles it started squealing and at 300 miles, a 2” wire started to stick out the side of the belt. I removed the gatorback belt (kept it in the truck as a back up belt) and bought a Dayco Poly Rib belt. After about 3000 miles it is still holding up.
Old May 19, 2018 | 08:30 AM
CamelChad's Avatar
Also running the Dayco. Haven't had any issues. I ordered mine from Rovers North, but also noticed the last time I was at Advanced Auto Parts that they have the exact same one.
Echoman
Apr 4, 2014 03:46 PM
alisaestmant
Member Group And Special Buys
Nov 7, 2013 12:57 AM
ShadowMerchantBC
Mar 21, 2011 08:10 PM
cptshanman
Oct 20, 2008 10:57 AM
