Bad start for new lr guy
Old Dec 29, 2012 | 01:25 PM
jmeyers278's Avatar
Default Bad start for new lr guy
Okay...had my 05 lr3 for a total of 2 days and it is on the hook going back to the stealer as I speak. It was making a driveline noise which after looking on this forum I'm guessing it is a diff problem....this morning....won't start. Turn the key and you get 1 click out of a relay...thats it. Not the battery, I assume the starter but the stealer had to tow it back to the shop and they can't look at it until Wed. because of the holiday...... Hope my LR experience gets better.....
Old Dec 29, 2012 | 01:39 PM
wheelgarage's Avatar
Not a good start. I hope you get it sorted....did you get an aftermarket warranty?
Old Dec 29, 2012 | 01:41 PM
jmeyers278's Avatar
No extended warranty....most aftermarket warranty companies don't offer lr coverage
Old Dec 29, 2012 | 02:16 PM
The one I have does.......I use Motorist Assistance Plan (MAP). I have the Platinum 48 month/50k mile plan. It covers EVERYTHING.
Old Dec 29, 2012 | 04:06 PM
Eniam17's Avatar
Whats the background on this vehicle, do you have all the maintenance records from previous owners? Did you have a pre-purchase inspection done by a good mechanic before you bought it to see if it had issues?
Old Dec 29, 2012 | 09:16 PM
jmeyers278's Avatar
I had it inspected and the only things found to be wrong were the low coolant sensor is bad and it needed a wheel bearing. After I took it home I noticed the driveline noise while under light acceleration. Other than that...no issues. I took it to the symphony last night to see pirates of the caribbean and it was snowing...all good...handles super in the slush...was totally in love. I got up this morning and click...no start!!
Old Dec 29, 2012 | 10:31 PM
stmcknig's Avatar
If it's the original battery then almost certainly due for replacement...if it's too low voltage or cranking amps to turn over the starter that would match. Had the same thing with my 07 - worked fine the day before, next morning, click....
Old Dec 29, 2012 | 10:35 PM
jmeyers278's Avatar
battery is brand new....voltage is correct....getting single click when attempting to start, jumping didn't help
Old Dec 30, 2012 | 05:46 PM
ktm_525's Avatar
Starter.
I currently have same thing and will attempt a replacement tomorrow.
Crawl under the passenger side and give the starter a tap.
FWIW the starter is a Denso. I went the cheapie rebuild route through Rockauto. $35 plus core charge beats the $400+ LR wants... I may get mine tomorrow. Appantly the starter replacement is a bit of a bear. Removal of ball joints etc. Welcome to LR!
Old Dec 31, 2012 | 12:48 PM
Evan Wiley's Avatar
any used LR can have issues and you need to be used to maintenance bills with them. Just do not go to your Dealer find a local British mechanic!!! After buying mine the dealer told me $3800 to fix a few things. Local British mechanic (British Auto Specialists offers mechanical repair and body work for British built vehicles, loacated in Calgary) was only $430. Best thing to do is take it in tell them you just bought it and due a Full Check on it. Once you have this done you will LOVE your LR...Trust me. I run with Jeeps and I almost never get stuck. To date LR3 =9 and Jeep 1 in current getting stuck. Expect your yearly bills to be 5-10K for Maintenance. I have my Hydraulics checked twice a year due to heavy 4x4ing, might be over kill but I hate it when a Jeep beats me on the road.
BTW if you did not get an Interstate Battery then you should replace it right away!!! ONLY use interstate if your not using the OEM batteries. A hard lesson learn for me.
