Battery light not going away!!!
Old Jan 9, 2019 | 09:15 PM
UZL247's Avatar
Default Battery light not going away!!!
New to the group so hello to everyone first! Writing from sunny Cabo San Lucas Mexico I purchased the truck used and having a few issues. To start the t-bolt on the + cable for the battery was missing. I replaced the whole fuse with a new one and I am still showing the battery light. I also get the suspension light which from all my reading should be the low battery wattage as well.
Thanks in advance. No Land Rover here so I have to troubleshot on my own. What would be my next step ?
P.S. Also bought a new battery so thats not the issue.
Old Jan 9, 2019 | 09:22 PM
Most likely the alternator is dead. When running put a voltmeter on it and see if the voltage is dropping.
Old Jan 10, 2019 | 05:42 PM
Atticus_6147's Avatar
Mine stayed on for months after a new interstate battery and alternator. But I changed my starter and it went away and hasn't been back.
Old Jan 11, 2019 | 09:11 AM
UZL247's Avatar
Well now thats a new one! I am also having issues with the suspension because of the bad voltage connection and sunroof failure. I will check the alternator and see where to go from there hang tight. JUST TO GET THE T-BOLT REPLACEMENT I HAD TO ORDER A WHOLE BATTERY POSITIVE CABLE FUSE BOX AND REPLACED THE WHOLE PART. 1 STEP AT A TIME
Old Jan 28, 2019 | 01:01 PM
kels83's Avatar
+1 on the alternator to fix low volts and battery light. I took mine into a local alt shop who said it was fine, went ahead and replaced it with a rebuilt Napa (USA) that ended up being a dud. I purchased a rebuilt denso alt from an ebay seller la-parts310 that finally ended my 2 month low voltage problems!
Also might check grounds and battery cables, lots of info on other posts.
Nov15
Jan 10, 2024 05:01 PM
PeetzLR3
Dec 11, 2023 11:21 PM
starcraft1
Aug 15, 2019 11:29 PM
robersonb
Jan 13, 2018 05:18 AM
tailchaser0527
May 14, 2008 07:05 AM
