battery terminal post connection expansion
Happy New Year all!
I had a quick question, does anyone have any recommendations on battery terminal connection replacement? Basically to allow additional items (lights etc) to be connected to the battery and/or eventually a dual battery setup.
Thank you,
James
Thank you,
James
There are 2 places on the Positive post that have threads for a 10mm head bolt that you can connect to. There are no additional places on the ground post however, grounds can be connected to any of the ground posts on the body close to the battery (or close to where the accessory is).
I ran a large wire from the AUX battery to a place in front of the aux battery box and added a small rely / fuse box for all the "other things" I want to run. I do have a large cable going to the Aux battery, and a large cable going to the winch and a large cable going to the front grill (I hate pulling apart the battery covers every time I have to jump start my friends old Chevy Blazer) and a small wire that runs to a volt meter.
So I suppose you can get at least three things on the main battery if you want.
Hope that helps
Jeff
Hope that helps
Jeff
