BG fuel injection/induction service
Old Jun 24, 2013 | 07:15 PM
thorgal's Avatar
Originally Posted by roverguy7
Rest of the pictures.
Wow,that is one clean Throttle plate,good job.I had to replace entire Throttle body due to Faulty sensor inside.
Old Jun 25, 2013 | 08:22 AM
er1c's Avatar
roverguy7, thanks for the pictures. They're nice and clear and a good reference for people.
Old Jun 25, 2013 | 08:57 AM
roverguy7's Avatar
The throttle plate is purely from the service, there was no physical cleaning at all. LR does not specify, but Jaguar(who makes the engine) advises against physically cleaning the TB, as you can remove a coating. If you look closely, you can see where the Carbon had somewhat changed the surface of the blade, both in the before and after shot.
Old Jul 2, 2013 | 03:58 PM
comleader's Avatar
Can anyone give me the part number for the capacitor? I talked to the parts counter at my local rover dealership and they have never heard of it...said the 2006 LR3 doesn't have one.
Old Jul 2, 2013 | 04:01 PM
comleader's Avatar
For that matter, can you include the PCV part number too? I don't trust that this parts person is giving me the correct price for the correct part. Does $46 sound right?
Old Jul 2, 2013 | 06:04 PM
jafir's Avatar
LR004160
Land Rover Parts - Land Rover Parts Center - Call (800) 574-9217 for Genuine Land Rover Parts and Accessories
Old Jul 2, 2013 | 07:41 PM
ghtaylor's Avatar
Dave,
I have a 2005 LR3 HSE w/67,000 miles. The dealer just replaced the MAF and about 6 months ago they replaced 5 ignition coil packs and diode as well as spark plugs. Should I have the fuel injection service you describe?
Also - should I have the 3 remaining coil packs replaced? It seemed add that they only did 5.
Any advice is greatly appreciated.
Gordon
Old Jul 3, 2013 | 12:20 PM
roverguy7's Avatar
An injection service is good, the cleaner things are, the better everything will work. Ideally you want to change the plugs after doing an injection service, as it is a very aggressive chemical, and can damage the plating on the plugs.
Why did you have 5 coils replaced?? They really do not fail that often, and when they do, it's at random, not several at once.
Old Jul 3, 2013 | 12:27 PM
jafir's Avatar
I've seen dealers (not just land rover) recommend replacing all of the coils. Probably just a cya. I will note that some of the rover parts places sell lr3 coils in packs of 8.
I've got some coils in order for mine, should be here Monday. I notice some have been replaced before. I think the previous tech failed to fix the problem because the lr3 manual gives incorrect cylinder numbering. I found a jaguar document online and it helped a bunch in figuring out what rover had labelled wrong.
Old Jul 3, 2013 | 01:55 PM
ghtaylor's Avatar
Vehicle went into reduced power mode - I had to crawl to dealer. They replaced one coil pack.
A couple months later another failed so I asked them to replace all as I was worried that I would be in a remote location when the next one failed. They only replaced 4 more as they were out of stock. Would you replace the other three?
I really appreciate the advice!
Gordon
