Biggest and Best Off Road Tires for LR3
Old Oct 5, 2011 | 10:00 AM
WCoffroad's Avatar
Default Biggest and Best Off Road Tires for LR3
What are the largest size and best performing off-road/all-terrain tires that will fit on the LR3 stock 18in rims without rubbing?
I am leaning toward the BF A/Ts but, also am considering the General Grabber A/Ts... what do you guys run? What is the most popular?
Old Oct 5, 2011 | 10:26 AM
perkj's Avatar
You willing to run suspension extension rods all the time?
Old Oct 5, 2011 | 10:45 AM
WCoffroad's Avatar
I will if it doesn't affect the handling, i.e., going around sharp turns and taking highway exits at high rates of speeds...
Old Oct 9, 2011 | 01:52 PM
Johnson Rods's Avatar
LR Forum Vendor
I recommend not exceeding 32 inches. I run 275-65-18 and they fit well with the rod lift. You can go about a half inch taller but will have some rubbing. The LR3 can fit a larger tire size than the LR4 by about 1/2 inch. I have a tire size chart here:http://johnsonrods.com
Size:  194.7 KBName:  DarrellinColorado.jpg
Old Oct 10, 2011 | 07:40 PM
WCoffroad's Avatar
That looks sweet.
Is that lift just the Johnson Rods in the link?
I was planning on Mickey Thompson ATZ 265/65/18. Will they fit without rubbing?
Old Oct 10, 2011 | 09:56 PM
jimbiram's Avatar
Yes...even with Johnson Rods, there will be some rubbing under severe compression or at access height, as they are larger in diameter than my Cooper Zeons which are 285x60x18
Old Oct 11, 2011 | 03:52 PM
LR Forum Vendor
The 265-65-18 will have some rub when off road. I do recommend the rods for that size tire as I think you are better off not compressing the tire into the well and lets face it... It's way more fun to have the extra clearance. There are guys that run the 31.5 inch tire without rods. Just be careful. The other reason I like the rods with that size tire is that the wheel well looks too full without it. http://johnsonrods.com
The lift on my vehicle is just the rods - no spacers.
Old Oct 12, 2011 | 11:26 PM
Spencerfitch's Avatar
275/65/8 is about the max with the lift, but if you ever have an air
Suspension fault it will go into limp mode and drop down and you can't move. Bottomed out in wheel well.
265/65/18 and 285/60/18 are your best bet
Old Jul 27, 2013 | 09:01 PM
Wolfmother.oz's Avatar
Smile Largest 18 inch tyires for my LR3
Hi friends
I have just fitted 285-60-18 COOPER LTZ to my 2005 LR3.
They don't rub at all with normal use at factory heights.
I have a JOHNSON ROD 2.5 inch lift kit to try on some trails
when I go away in October, 13.
I have had a lot of resistance at tyre suppliers who are sometimes
unhelpful in Australia when modifying factory style equipment.
I believe that the USA has more COOPER tyre options than OZ.
I love my tyres and my JOHNSON ROD kit.
Regards
Neil
Old Dec 17, 2013 | 08:47 AM
jerdog53's Avatar
I dont see any Cooper LTZ in anything other than a 20", they must have stopped making the 18'....
I stand corrected, I did find some they are just wider than I would like.
