both keys stoped working
Old Nov 30, 2009 | 09:33 PM
mummra's Avatar
Default both keys stoped working
this morning i tried to open m door only o find that both of my remote kes will not work. o i had to stick and turn manually. The roer starts and the display does not indicate that the keys need charging. Is this a sensor problem or a electronic door lock problem? Or?
Thanks
Old Mar 10, 2010 | 03:07 AM
Wilky1978's Avatar
I had that problem also and then one day it was acting really weird and I couldn't even start my truck. It turned out that there was a wire that was jacked up under the driver seat. They fixed it and I haven't had a problem with it since. Have you had the shop take a look at your problem?
Old Mar 23, 2010 | 11:09 PM
hell pie's Avatar
I recently had a similar problem, with both remotes not functioning. This thread from another forum has some excellent answers.
http://www.landroversonly.com/forums...15/index2.html
Old Mar 24, 2010 | 05:49 PM
Rovin4life's Avatar
water leak into the passenger side footwell causes the splice to go bad.
nows a good time to fix that water leak causing you lots of problems as well.
Camdisco24
Sep 2, 2015 09:09 AM
binvanna
ROAMING WITH FRIENDS
Jan 22, 2013 01:56 PM
Jo1175
Dec 9, 2011 06:56 PM
llPANCHOll
Apr 22, 2009 02:53 PM
englc
Jun 4, 2008 05:43 PM
