brake pad wear sensor/chassis vin ??
Old Sep 18, 2016 | 01:47 PM
Jeff Miller's Avatar
4wd High
Default brake pad wear sensor/chassis vin ??
I'm changing pads and need a sensor. Apparently there are 2 different ones depending on chassis vin. Where is this number located, I can't find anything in the manual, and someone asked here and didn't get an answer?
cheers
Old Sep 18, 2016 | 08:55 PM
Best4x4's Avatar
I had my RR sensor break when I was doing my brake pads/rotors. I simply cut the end off (where the sensor broke) and shorted the two wires together used a beenie with silicone in it, and zip tied it completely out of the way. No more problems for me.
Sorry, but I'm not gonna deal with those silly delicate sensors every time I have to work on my LR3 when I can check the brake pad thickness myself at every oil change. 60.00 I can spend (for the pair) on other things.
Old Sep 18, 2016 | 09:00 PM
jafir's Avatar
It's the last part of the VIN, starting at digit 10 in this case.
Old Sep 19, 2016 | 11:37 AM
4wd High
Cheers!-for some reason auto parts person was confused. Makes perfect sense now.
04duxlr
Oct 15, 2015 08:42 PM
Disco Alan
Apr 1, 2012 07:29 AM
ticex
Aug 8, 2009 05:52 PM
tsuami1
Mar 1, 2009 09:32 AM
negativecapability
May 7, 2008 03:21 PM
