brake sensor - how do you know which caused the warning on dash???
Old Aug 15, 2009 | 05:50 PM
Dan_da_LR3_H2_man's Avatar
Default brake sensor - how do you know which caused the warning on dash???
I am just changinf all my brake pads on all wheels. I'm doing it cause the dash is giving me the annoying 'check pads' beeping and message every 30 seconds. I checked both the front and back and they all have at least 25% left but overall they look about the same amount left. I assume the front sensor is the one that caused the warning but how do I really know? I do not want to replace the front sensor if the rear sensor is the one that went off.
Is there any way to tell?
Thanks
Old Aug 15, 2009 | 10:05 PM
Finished the pad replacement and I installed a new front sensor assuming that was the one. Sure enough the annoying warning is gone. When I took a closer look at the original front sensor and the new one, I see what makes it go off. Basically it has a small plastic grove sticking - once the pad gets to about 20% this grove will be flush with the pad an slow cause the plastic to wear as you apply brakes. ONce the plastic is gone, you see metal in the grove. I suspect once the plastic is worn away and the metal is present, the metal causes the sensor to go off.
I wonder if the sensor can be "repaired". I was thinking of adding some melted wax or something over the remaining metal grove to make it work again? What do you think.
Oh, I noticed on ebay that you can buy either front sensor or rear sensor but on the pictures they loook about the same. Is there any difference - can I use a rear sesnor for the front and vis versa?
Thanks
dirklemond
Oct 24, 2012 01:39 PM
calebbo
Oct 12, 2011 09:54 PM
Savannah Buzz
Jun 16, 2011 09:20 PM
94svt50
Mar 18, 2011 08:11 AM
Chris-bob
Jan 21, 2011 11:54 PM
