Braking system
Braking system
My 2006 LR3 4.4K when not driven for a few days starts off with a hard brake peddle making stopping difficult at first but after a couple of stops works fine and will continue to work fine until left idle for a few days. I did have the rear brakes replaced recently and notice the brake fluid is above the max refill line. Any ideas would be greatly appreciated.
I would start by correcting the fluid level but it sounds like the booster on master cylinder may be going bad. One cheaper thing to do before changing parts would be to flush the brake fluid, you could have air in one of the lines. I also wouldn't take it back to that shop if they can't do something simple like make sure the fluid isn't over filled after changing pads.
Braking system
Thanks for the information. When i checked the fluid level again it was slightly below min this time. I assume it had air in the lines. I filled it up to the max level. The fluid was a little dark so I will have the
lines flushed and bled and hopefully that will solve the problem. I sure don’t want to replace the master and/or booster unless it’s necessary. How do you determine which needs replacing or do you just replace both if your replacing one?
As far as testing the brake booster I would recommend looking up the factory service manual and see what they show for testing. I haven't heard of boosters being a common issue for the LR3 so I wouldn't worry too much about that until you bleed/flush the brakes and do a quick test of the master.
