96' DI Brake Problems
Old Dec 5, 2009 | 10:27 AM
Disco Cory's Avatar
Default 96' DI Brake Problems
So my brakes are weak, as in it's difficult to stop from just rolling at 5mph. The brake pedal doesn't just drop to the floor, but it consistantly pushes fairly easy down, and pumping it doesn't change how it feels at all, no matter how fast, slow, or how many times you pump it.
I tried clamping off the flex lines to isolate the problem, but it didn't change how the pedal feels.
I don't see any fluid leaking anywhere externally.
I thought about changing the brake fluid, but I have a feeling that it's either the brake booster, or the master cylinder. I'm not sure how to know if it's one or the other though.
What do you guys think?
Old Dec 5, 2009 | 10:30 AM
llPANCHOll's Avatar
Step one.
Bleed the brakes.
Old Dec 5, 2009 | 02:33 PM
Disco Cory's Avatar
Ok, will do.
Old Dec 6, 2009 | 06:28 AM
antichrist's Avatar
Better yet, flush the brake system so you have all new fluid. Odds are it's never been done.
Also, if they've never been replaced the flex lines at the axles are probably way past their replacement time. They swell inside over time and give you spongy brakes.
Frank4
Mar 21, 2014 05:21 AM
sflowr03
Jul 5, 2007 11:18 PM
nate13
Jun 22, 2007 11:00 AM
mbrummal
Apr 1, 2007 08:14 PM
gerk
Apr 12, 2006 02:30 AM
