Broken Fan
Old Jan 24, 2015 | 01:18 PM
Bravhefen's Avatar
Default Broken Fan
So last night, I heard a funny noise while accelerating, It got worse, then the whole car began to wobble upon idle, I limped home and found that my upper fan shroud was shredded to pieces and my fan was broken and a small upper radiator hose had been torn off. First of all, what in the world might have caused this?
I can replace the fan myself no problem for under $400 and I probably need a new radiator, another $350. I can't seem to find a new fan shroud though.
Any thoughts? Anyone experience anything like this?
Any help and discussion on this would be very helpful.
Old Jan 24, 2015 | 03:31 PM
bmeier's Avatar
What model you got? If its a D2 I can tell ya, you can get those replaced alot cheaper.
Old Jan 25, 2015 | 12:30 PM
Bravhefen's Avatar
I have an LR3 06'
Old Jan 25, 2015 | 06:05 PM
unseenone's Avatar
You can pick up a fan shroud at a salvage yard, or through their network. You can also search for LR3 used parts..
I'd inspect the bottom front lower shrouds, either something made it's way in, or a blade let loose and tore everything up. The conditions you were operating in at the time may give you an idea, ie: high RPM, gravel, hit a wood chuck, etc.
bbaileyii
Sep 27, 2013 09:08 AM
rrhyne
Jun 8, 2010 09:13 AM
rover1978
Sep 26, 2009 09:05 PM
jmt
Jan 14, 2008 05:01 PM
