Broken Negative battery lead.
Old Feb 3, 2019 | 02:36 PM
RoverCraig's Avatar
Default Broken Negative battery lead.
Ok,
Resetting codes, took off the Negative battery lead.... BUT, when I went to tighten it back on, the threaded part snapped, so, I cannot properly tighten the negative battery lead. So 2 things,
1. Is there a way to Jimmy this until I can solve the issue, I dont want the lead coming off while driving.
2. Is this a hard part to find, I can't even find the name for it, its just a bolt really, it seems to me.
Old Feb 3, 2019 | 07:06 PM
battery terminal is what your after
https://shop.advanceautoparts.com/c4...nals/-49997255
Pick up a new terminal and if there is enough cable you can swap in the new and move on with life. The bolt on style should make it pretty easy to do, you can strip the wire with a razor blade if you need.
Disco Eagle
Mar 10, 2019 05:30 AM
LADisco2
Nov 15, 2016 03:48 PM
aemnky606
Nov 12, 2016 11:38 AM
oilspotLR
Aug 21, 2012 09:55 AM
hummermaniac88
Freelander
Jul 5, 2009 02:08 PM
