C1130 Code Air Spring Air Supply..Fault Code ?
Im saying our cost is about that, he will mark em up. I think the center is like $120ish and the front/rears are closer to $200 each. You would just have to check the AB site.
Oh so they are not as inexpensive as he thinks..
We are taking car in on Monday as Brake Fluid is leaking and he will look into the Suspension Fault code Lines you pointed out..as I get the suspension fault every couple of days.thank you
Hi..this was solved it looks like..Mechanic lifted Car and heard in front right Air Strut..ssssssssssss.
So we ordered two OEM Delphi from Atlantic British and so far a few weeks and no more Suspension Fault Code..thank goodness. : )
