Can the front transfer release block cause fault codes
Hi guys,
I just posted in the new member section. I just moved to Canada with a Defender 110 2000. However I have been helping a friend with several air suspension issues on his 2006 LR3.
He had two leaky bags so I replaced the two front ones with Arnott units and they still leak. I can't identify a leak at the airbags anymore so I suspect the transfer release valve block that sits in front of the passenger side (LHD truck) front wheel behind the wheel well cover.
If that valve has an internal leak, it would cause the front of the truck to lower.
However, the truck often has suspension fault and lowers to the bump stops. Can that valve cause that fault? Or should I look elsewhere?
The valve is not that much so we will order it but my nanocom does not scan the Disco 3 (I don't have the unlock codes for that).
Thanks for the help!
David
David
mcvayrover
01-08-2024 11:50 AM
kbarker27
10-13-2023 04:03 PM
06Range
05-08-2013 09:01 PM
vandal996
01-12-2011 12:43 PM
