Changing Brakes
Old Oct 24, 2010 | 04:27 PM
grkrover's Avatar
4th Gear
Question Changing Brakes
Currently have an '08 LR3 and need to change my brakes at about 24k miles. The sensor has not popped yet but dealer recommended that I change them out along with the rotors.
Needless to say, I am only changing the brakes at this point but when I attempted to do so the air suspension dropped the car automatically when I went to jack it up. Is this normal?
The manual says to lock the suspension of which I am aware that other cars are able to do but the same thing happened when I thought I had locked it. It doesn't seem the locking worked but do I just ignore this and proceed to change the brakes and if so will this affect the suspension in any way?
Old Nov 6, 2010 | 01:44 PM
Can't help you with the suspension but want to know what brake pads you are planning to install, this is important if you don't want squeaking, brake dust and having them wear out again so soon?
Old Nov 8, 2010 | 05:45 AM
grkrover's Avatar
4th Gear
I am planning on installing the EBC brakes along with the sensors even though they have yet to pop.
As for the suspension, since this occurred my only concern now is if I ever need to change a flat. I am wondering if I should drop the car and then jack the car.
My tires also need changing so if you have any recommendations, I'll take them. Seen so many on the forums.
Thanks Mike!
Old Nov 8, 2010 | 12:40 PM
If you haven't purchased them yet, you might consider buying Akebono ceramic pads, they will last longer, make no dust, stop better and not squeak.
FightOnUSC79
Nov 26, 2010 09:43 AM
amvauto
Sep 18, 2008 07:38 PM
hollis
Sep 5, 2008 12:53 PM
m1964
LR2
Jun 15, 2008 10:06 PM
flygirl92
Apr 29, 2008 03:48 PM
