Changing Tires - keeping the suspension up
I'm lucky enough to have two sets of tires, a 19'' set for around town and long trips and a set of 18's with 285/60/18's for the dirty stuff. Every time I've changed them at home I've struggled with the suspension extending so far I have trouble getting the wheel off. I searched the forums for a trick and haven't found any that work (Off road height and leaving doors open etc). Curiously the one time I had to change tires on the trail I didn't have any issues. Tips, Tricks, Secrets? Thanks
The owners manual says to set the truck in off-road suspension height, while truck is running, allow it time to adjust, turn off, then jack vehicle. This doesn't work and creates the scenario you described. I jack the vehicle in normal street ride mode. When lifted, the auto shocks self-adjust a little bit, but not to extent you refer to. If you're changing wheels, it will be even easier to use your floor jack and lift one whole side of truck at a time. Always use jack stands just in case.
I've tried both methods you describe with little success. I've settled on a routine of using the floor Jack to raise the corner up, placing a jack-stand and lifting the control arm with the floor jack and a block of wood to raise the wheel. It just shouldn't be this hard. And I certainly wont have the floor jack on the side of the freeway.
Lol, I had Americas Tire do a tire rotation for me and the mechanic did exactly that. They ended up paying for a new compressor setup.
llaniD
03-25-2009 10:22 AM
Speed racer
09-09-2008 03:05 PM
