clutch pedal bracket
Old Dec 8, 2020 | 04:25 AM
Paul28559's Avatar
Default clutch pedal bracket
Hello,
a question about the metal bracket which holds the clutch pedal in place.
i have a 2005 lr 3,
there are 2 metal brackets positioned on either side of the clutch pedal. the bracket on the gearbox side has cracked / torn / started to break. i sourced a replacement from a breaker and i can see the commencement of a similar crack in that bracket.. this pedal is a bugger to remove when the drivers seat is in place
is this an known problem?
is there a replacement after market bracket out there or do i just keep welding it ever time the break starts to interfere with the functioning of the pedal.
thanks
Marco Jeroen Pieren
Mar 18, 2020 02:17 PM
Racoonatwork
Apr 27, 2016 08:46 AM
buttocks
Dec 31, 2014 12:53 AM
tornado_735
Jan 31, 2011 10:12 PM
Scottish Wildcat
Jan 23, 2009 02:49 PM
