clutch pedal bracket
Hello,
a question about the metal bracket which holds the clutch pedal in place.
i have a 2005 lr 3,
there are 2 metal brackets positioned on either side of the clutch pedal. the bracket on the gearbox side has cracked / torn / started to break. i sourced a replacement from a breaker and i can see the commencement of a similar crack in that bracket.. this pedal is a bugger to remove when the drivers seat is in place
is this an known problem?
is there a replacement after market bracket out there or do i just keep welding it ever time the break starts to interfere with the functioning of the pedal.
thanks
i have a 2005 lr 3,
thanks
Marco Jeroen Pieren
Mar 18, 2020 02:17 PM
buttocks
Dec 31, 2014 12:53 AM
