Coil pack bolts won't come out.
Old Oct 10, 2020 | 07:47 PM
Redpoint510's Avatar
Default Coil pack bolts won't come out.
Hi everyone. Got a Cyl 8 misfire hit and decided to change all the plugs as a starting point since it needed to be done anyway. Almost all of my coil pack bolts will not come out. They simply turn and turn. My assumption is that the brass nutcerts in the valve cover have broken loose and are just spinning with the bolts. Has anyone run into this issue? This is the 4.4 motor. I believe this motor is multi platform and came in Range Rovers also so it should be a widely used motor so I'm hoping someone else has (unfortunately) run into this issue. So far as I can tell it's looking like the solution is to replace the valve covers which is going to be a massive pain. Any thoughts or advice would be very much appreciated.
Thanks in advance.
Old Oct 10, 2020 | 08:23 PM
DakotaTravler's Avatar
There are no coil packs on the 4.4, just individual coils.
I have not seen or heard of this issue. I wonder if someone was in there before and used a powered tool for reinstall and stripped em? I hope not. Have you tried to VERY gently tap them down? I have seen inserts pull up if over-torqued, so tapping them a little helps them bite a bit more. Otherwise if they really are spinning that free you should be able to just pull em up. Then you could get a different size, slightly larger. Drill and insert new ones.
Old Oct 10, 2020 | 10:15 PM
I have never ran into that either on any of my 3 LR3's
Old Oct 10, 2020 | 11:07 PM
Best4x4's Avatar
Yeah I haven't run into that either on the LR3
Old Oct 11, 2020 | 08:50 AM
Ok ok coils, coil packs, you obviously understand what I'm talking about... Thanks for pointing that out.
Old Aug 15, 2021 | 01:32 PM
Keiths5n10's Avatar
8th Gear
Thanks in advance.
Same issue drivers side (LH) rear by firewall, spinning spline/stud, going to figure out a way to pry it up/ out..
Old Jun 18, 2022 | 07:24 PM
rsdawson84's Avatar
Default Following Up
Just wanted to see if anyone had a solution. I’m having the same issue with number 6 on a 2006 LR3
Old Jun 21, 2022 | 10:43 PM
Identamerican's Avatar
Take a nail puller, and your ratchet. Use the nail puller to apply somewhat gentle upwards pressure on the bolt as you turn it. Then, ideally, rethread or replace the insert.
Jeff Blake
Jun 30, 2016 09:13 PM
Colorado David
Jan 21, 2014 06:13 PM
humroot
Jul 23, 2012 08:46 PM
randyt777
Nov 30, 2011 07:06 AM
roversprings
Feb 21, 2011 10:50 PM
