Cold Climate and Air Suspension
Old Jan 16, 2022 | 07:23 PM
Land Over's Avatar
Default Cold Climate and Air Suspension
Seeking some input from the owners in Canada and Northern US. My 06 is due for the air strut replacement. It spends its time between Denver and Casper Mountain Wyoming. Up north the temps can easily be in the below zero (Fahrenheit) area for multiple days in the row, so, I need to decide whether to convert it to coils for fear of the bags cracking in the cold, or stick with air. What is your experience in the cold temps? Thanks
Old Jan 17, 2022 | 01:36 PM
kajtzu's Avatar
0 Fahrenheit is only -17.778 celsius. No issues with suspension. A well maintained D3/LR3 won’t have any issues. As you have a petrol you won’t have issues starting, either, as long as your battery is good. Here in Finland I’ve started weeks at a time at -29 Celsius and it’s fine. Not aware of any urban legends w.r.t. airbags splitting either.
YMMV.
Old Jan 17, 2022 | 02:36 PM
houm_wa's Avatar
Only thing kinda related that I've heard is that when parking, especially if it's for days or weeks at a time, you should vary the position (i.e. Access v Normal v Off-road) that you leave the EAS in so that it doesn't develop creases. I could see this being exacerbated in a cold climate, too.
Old Jan 18, 2022 | 01:02 AM
DakotaTravler's Avatar
Air bags cracking cause of cold? Are you going to remove the rubber wheels too? Air suspension has existed longer than almost any modern suspension setup. They won't crack in the cold.
Old Jan 18, 2022 | 08:01 PM
Land Over's Avatar
There is a difference in thickness of a wall on a tire and and that of the air bag suspension. Rubber and cold don't like each other. All I was trying to gather is what other people have experienced.
Old Jan 19, 2022 | 12:54 PM
enb54's Avatar
I have not experienced any problems with mine in temps down to -40C (-40F), but I have a fairly new Hitachi compressor and if I have airbag problems will likely replace with Arnotts. If well maintained an air suspension should not be problematic in cold weather, my son has a Lincoln Aviator with air suspension, no complaints...
Old Jan 19, 2022 | 07:00 PM
rusty's Avatar
3rd Gear
The only issue I have had in the cold/snow conditions in when snow/ice compacts on/around the height sensor, it will act as an obstruction and go into extended mode. After a few attempts to lower the suspension it seems to dislodge the obstruction and work fine.
humroot
Jul 20, 2007 03:49 PM
amvauto
Mar 6, 2007 06:22 PM
tripz
Jan 4, 2007 05:58 PM
karenandharry
Feb 10, 2006 02:02 AM
