Compressor R&R Advice sought
Old Jun 5, 2023 | 10:20 PM
houm_wa's Avatar
Ah hah! Ratchet ring spanner....that's a tool I don't have. I'll need that; any particular size?
So you are saying undo the bolts that hold the compressor to the bracket, move it to one side and get the top bolt, then take down the entire bracket with compressor?
Old Jun 5, 2023 | 10:24 PM
loanrangie's Avatar
Correct, 10mm but id get a set if you are buying.
Old Jun 6, 2023 | 03:07 PM
houm_wa's Avatar
Called to get a quote from a local shop just to have a data point. They said they won't install the Hitachi because the fault remains present; AMK only.
Are they off their rocker?
Old Jun 6, 2023 | 07:25 PM
keninnc's Avatar
They may be confused. If you replace the compressor with a different version and don't change the setting using the Gap tool you will get a code. That is what they most likely think will happen.
Swivel socket and not a universal joint is the key.
The notch is a great idea also.
Old Jun 6, 2023 | 07:50 PM
houm_wa's Avatar
That's what I figured....they probably had customers come in with a Hitachi to replace a failing AMK.
Old Jun 17, 2023 | 09:42 AM
jh.'s Avatar
jh.
Hi all,
I just got a Hitachi compressor to replace my tires Hitachi compressor in the '06. I am gonna replace it myself. I've never done this. I've watched a few YouTube videos so I have an idea of what's coming.
Any advice on helpful tools? Procedures? Tricks? Much appreciated, in advance.
@DakotaTravler @P-Bod
-Houm
How’d it go? I just swapped mine yesterday and it wasn’t as bad as I remembered it from 6-7 years ago. Only casualty was the 4mm bolt at the middle of the sound deadening clamshell. Otherwise, now the bracket is notched and no faults (yet). Pretty quick - maybe 4 hours with a lot of beer and casual breaks. $350 Amazon Hitachi … cautiously optimistic!
Old Jun 19, 2023 | 03:07 PM
houm_wa's Avatar
I'll be doing this job on Wednesday afternoon! I enlisted the help of a friend that has done this several times, so I should be getting some good tutelage. I'm bringing the pizza and beer, he is providing insight and emotional support.
Old Jun 19, 2023 | 06:17 PM
DakotaTravler's Avatar
Well if they did it several times, it should take half a beer to get it out and another half to get it in. That is how I am with fuel tank removal now. Silly how long the first time it took me, now I can drop one in just a few minutes.
Old Jun 19, 2023 | 09:13 PM
houm_wa's Avatar
I'm still happy to put in many beers and hang out with my homie for a few hours while I learn the ropes.
Old Jun 20, 2023 | 09:46 PM
jh.'s Avatar
jh.
I was probably 3-4 on the way out…several in between…and 1-2 back in. I prefer my methods to yours
