Control arm replacement cost
Yeah, indeed a clunk could be other things. If the upper rear arm, then both should be replaced. If they are at all familiar with the Rover, then the cost will be two arms and likely a new upper rose joint on each side - assuming that bolt is frozen inside, which happens a lot. The upper inside bolts probably need to be cut. Since shop prices vary so much, it is hard to give a number but over $500 I would think and probably a little over $1k.
Tks. I’ll be calling a shop next week to make an appointment to have it looked at as well as a good look around. The truck is new to me so think it’s probably a good idea to know if there are any items that need addressed. The shop advertises itself as a Land Rover Indy shop so hopefully they know what they are doing.
