Control arm replacement cost
Old May 28, 2023 | 12:44 AM
Columbiar's Avatar
Default Control arm replacement cost
What would be a fair price to have this work done at an Indy?
Old May 28, 2023 | 08:47 PM
DakotaTravler's Avatar
$50.00
Kidding... need more details. ALL the arms? Just one? OEM parts? I mean one arm, a from lower for example, could take a couple hours to cut out and replace with new. Not to mention the alignment.
Old May 29, 2023 | 01:31 AM
Columbiar's Avatar
Tks. Hearing a clunk in the rear. Will be taking it in by was just looking for what kind of financial pain I’d be looking at.
Old May 29, 2023 | 07:39 AM
houm_wa's Avatar
Clunk in the rear could be swaybar bushings, too.
Old May 29, 2023 | 08:18 AM
Yeah, indeed a clunk could be other things. If the upper rear arm, then both should be replaced. If they are at all familiar with the Rover, then the cost will be two arms and likely a new upper rose joint on each side - assuming that bolt is frozen inside, which happens a lot. The upper inside bolts probably need to be cut. Since shop prices vary so much, it is hard to give a number but over $500 I would think and probably a little over $1k.
Old May 29, 2023 | 12:29 PM
Columbiar's Avatar
Tks. I’ll be calling a shop next week to make an appointment to have it looked at as well as a good look around. The truck is new to me so think it’s probably a good idea to know if there are any items that need addressed. The shop advertises itself as a Land Rover Indy shop so hopefully they know what they are doing.
spinach_e
Jul 8, 2023 09:34 PM
Luke87GT
LR4
Jan 21, 2023 08:49 AM
thorgal
Apr 1, 2019 02:58 PM
RickyN29
Jun 13, 2018 11:54 AM
demelvin
Jul 30, 2008 10:24 AM
