Coolant Temp Reading from “secret” radio menu
Old Apr 30, 2022 | 03:49 PM
Johnpb's Avatar
Default Coolant Temp Reading from “secret” radio menu
So still getting to the bottom of my lean bank 1 and 2 code. Since the CEL usually illuminated as I’m on the power, I’m kinda leaning towards replacing the coolant temp sensor. Can anyone check that secret menu you access through the radio by pressing and holding the station-adjustment ****?
Mine says: “TEMP 80 and TEMP 54”
thanks…. I’ll get to this solution one day🙄
Old Apr 30, 2022 | 06:02 PM
DakotaTravler's Avatar
If 80 is coolant, that is low since engine temp should be just over 95c. But this could also indicate a t-stat that is not fully closing.
Old Dec 10, 2024 | 10:47 AM
GlenhurstFarm's Avatar
3rd Gear
Default Old thread, I know!
So the top left number I’m not too sure of, top right is obviously your current volts.
The middle left (80) is the adjustable high temp shutdown for your radio!
Bottom left I think is the adjustable timer to when the high temp shutdown kicks in, once it trips.
Coyote
Jun 24, 2013 03:24 PM
GamecockRover
Oct 30, 2012 05:29 PM
ckemp
Jul 10, 2012 09:41 AM
willlane
Jan 4, 2008 09:05 AM
yoeman
Jan 28, 2006 11:21 PM
