Cruise Control Troubles
I actually just did all of the brake lights a couple weeks back since I was going down the path of brakes sensors might be playing into it. I'' dive into the Alternator since the vehicle is now pushing 16 years and 270k its a good chance. Ill check it out tonight and see what I find. Thank you for the idea
I did the brake switch already and watched it with the GAP (live values) to make sure it wasnt doing anything weird while I was driving which would cause it to not enable cruise control. And Ill check out the buttons under the live values to see if its properly seeing it, thanks. I ran through some alternator testing suggestions I found online as well but I didnt do it long enough to properly see if it was charging the battery while a load was being applied.
Reporting back to everyone who has helped me. So I tested the battery with and without loads and during crank and my 6 month old battery dips below 9.8v during crank and before crank with no load and just the ignition set to acc it will sit around 11.8 to 12.4. So I decided to charge up the battery via a battery charger and sure enough its sitting low even though I was out yesterday driving for nearly 4 hours (so it should be fairly charged up). After charging the battery for 4 hours Im not getting the Transmission Fault during start but shortly after (within 60 seconds) the cruise control will stop working. And this time around Im getting P0579-00 Speed Control Multi-Function Input ! - Circuit Range/Performance which I wasnt getting before. Im going to go down the route of fixing up the battery and possible alternator issues before I bother you guys anymore on this one. Thank you all
rocky1
09-12-2017 11:13 PM
