dash alerts need help (new)
Old Nov 8, 2015 | 08:42 PM
  #21
TOM R's Avatar
My parts truck had all dash lites on, I cleaned the
Drains, sopped up all water and left it sit a week with a board holding up the carpet and problems resolved themselves , sometimes you get lucky
Old Nov 8, 2015 | 09:50 PM
  #22
kb24's Avatar
Awesome man, I will try that and see if I get lucky too.lol
Thanks a lot on the quick reply and the links, appreciate it a lot.
Old Nov 9, 2015 | 10:41 AM
  #23
TOM R's Avatar
If the splices pull apart you will need to clean the wire it strip it back to clean wire then cut out the bad and solder in new wire then shrink tube it , this is the real suck part cause the corrosion travels up the wire, I have had limited luck cleaning the wire by soaking for a minute with muratic acid, do not breath it, sometimes it cleans the corrosion off so you can solder, if its real bad do what I first mentioned
Old Dec 31, 2015 | 10:36 AM
  #24
kb24's Avatar
Thanks for the advice, ill try to get that taken care of when i can, right now im trying to just get the LR3 to pass emissions and I keep getting a brake light sensor coming up on the computer.
I replaced the brake light switch but it didnt work.
Could this be the wiring under the passenger side thats causing this to trigger?
I got my sunroof drain clog fixed at the dealer on that side but im assuming the wiring still needs to be fixed, im just trying to avoid doing it somehow if I can clear the brake light sensor.
Thanks
jycsalas
May 22, 2015 09:05 AM
930
Jun 23, 2012 06:00 PM
candy
May 11, 2012 06:34 AM
Ted Sims
Jun 6, 2009 07:59 PM
tonyzp007
Jan 26, 2007 11:21 PM
