Dashboard
Old May 15, 2019 | 07:21 PM
mtaylo32's Avatar
Default Dashboard
Has anyone had this issue happen?! Any solutions?!
Old May 15, 2019 | 07:24 PM
mtaylo32's Avatar
trying to attach a video, but my dashboard will go dark when the car is running and come back. Speedometer and other information looks as if the car were off, but it’s on. Any ideas? New cluster?
Old May 15, 2019 | 08:08 PM
DakotaTravler's Avatar
My dashboard is black. I assume you mean gauge cluster or nav/info screen?
Old May 15, 2019 | 08:18 PM
mtaylo32's Avatar
When car is first started.
After a moment of idle. Car is on.
Yes info screen and speedometer. Can’t seem to attach a video, but here are screen grabs.
Old May 15, 2019 | 08:19 PM
mtaylo32's Avatar
Once it comes back on the information screen goes black and then comes back to normal. It’s the strangest thing.
Old May 15, 2019 | 08:20 PM
Wow, thats a new one. I guess I can not help on this one much. It looks like a failing cluster, bad connection or faulty relay. Is this sequence you describe repeatable with every startup? Have you done a hard reset (disconnect battery)?
edit: Or possibly a failing battery, how is your alternator/battery health?
Old May 15, 2019 | 08:23 PM
From another site:
"There is a single big cable connector on the rear of the instrument cluster that over time works loose. That is probably why you have a "now you see it, now you don't" intermittent kind of problem.
The link below shows a picture of the rear of the cluster and the location of the plug in the top corner.
The trick to is get at the plug but once one does, you just unplug it and replug it back in.
I suggest you disconnect the battery prior to unplugging etc so that you know all the computers are dead so when you restart, there will be other fusses."
https://disco3.co.uk/gallery/albums/...D3_Speaker.pdf
Old May 15, 2019 | 08:32 PM
Also, water ingress. Do you have any water entry issues? Wet carpet, etc?
Old May 15, 2019 | 09:05 PM
mtaylo32's Avatar
This is awesome information Dakota! Always appreciate your input with all these problems. I’ll give the connector a shot. It doesn’t happen with every start, it is very random. Probably the fourth time this has happened in the last 2-3 months. Definitely no water ingress or any signs of water anywhere. The car is really in great shape, now seem to have all these problems happening at one time. Otherwise car has been fantastic in the 3 years I’ve owned it.
Old May 15, 2019 | 09:09 PM
Well, still check for water by pulling up the carpet. It has a VERY thick pad so you need to sorta dig into things a little. And check your charging status, make sure electrically things are good. You can do so onboard, see video below. Make sure battery connections are tight. I would do all that first before checking the cluster.
In the video, press hold the first show location in that random no-button area for six seconds. Then the lower physically button until the code screen comes up. Crap video, but give you an idea. Voltage is under vehicle signals menu.
Aeteocles
Dec 13, 2018 09:56 AM
jackatcar
Sep 20, 2008 08:39 AM
97LANDISCOVERY
Feb 7, 2008 09:38 AM
skylinegtr
Nov 14, 2006 07:17 AM
