Daughter's LR3 dead in the driveway
Old Dec 5, 2019 | 05:54 PM
Husker's Avatar
So we just got it from the mechanic. He said they drove it, started it numerous times, no issues.
It's done fine for a half hour. Now while driving, the emergency flashers are coming on again, the radio is off, the NAV screen is off, and a message something to the effect of "shutting down."
Is this still potentially a battery issue? Can Autozone tell me if it's on the blink?
Old Dec 5, 2019 | 05:55 PM
Wonder if it's charging consistently
Old Dec 5, 2019 | 05:59 PM
Husker's Avatar
[img]blob:https://landroverforums.com/07226115-8e24-469e-973a-dc3768e01bf7[/img]
Old Dec 5, 2019 | 06:04 PM
Husker's Avatar
If it was a battery issue, wouldn't we have dim headlights, weak cranking, etc.? Or not necessarily?
Old Dec 5, 2019 | 07:17 PM
loanrangie's Avatar
Typically yes, battery may be ok but alternator is dying. Test the output with a multimeter both running and about 1hr after shutdown.
Anything over high 13-15V while running is good, mid 12 - 12.8V standing is good.
Old Dec 5, 2019 | 07:19 PM
Have you considered that the radio is pissed because you were planning on replacing it
Old Dec 6, 2019 | 10:53 AM
douglastic's Avatar
Yes AutoZone can load test battery, alternator, and starter for free.
I can't vouch for the quality of the tech/test though - but should at least give you some answers.
Old Dec 6, 2019 | 12:08 PM
Husker's Avatar
Battery tested strong. It's only a few months old.
Back to the shop!
This is crazy. This is a low miles, well-taken-care-of LR3. I am the third owner.
Maybe I just had some bad luck and it will work out great after this deal.
I called my mechanic and he said he likes working with electrical and to send it his way.
Old Dec 6, 2019 | 01:44 PM
abran's Avatar
It has to have codes with those faults.
if you rule out battery and alternator I would guess instrument cluster.
if you have communication codes from other ecus to the cluster, that’s your smoking gun.
Old Dec 6, 2019 | 01:59 PM
Husker's Avatar
One thing about all of this, I'm definitely learning a lot about cars. i don't recall an instrument cluster issue in my life, and I've owned over 50 cars to date.
If it's the cluster, I am scouting ebay for one now. I am finding ones "with message center" and "without message center". Which of these do I need? And I am understanding that the cluster can be reprogrammed to my vehicle with a GAP tool?
