Disconnect Battery to reset TPM
I have been experiencing intermittent TPM system faults for a couple of months but more recently the error message comes on everytime I start the truck and never turns off. Pep boys replaced two bad sensors and confirmed that all 5 (including the spare) are functioning & transmitting correctly but the warning won't go away. I have read that disconnecting the battery for 15 minutes will "hard reset" the system which would cause the sensors to re-stablish communication with the truck and possibly save me from having to replace the module.
Seems like there is nothing to lose by trying, but I wanted to see if there is anything LR-specific I need to know about disconnecting the battery. I am coming from a BMW that basically required a computer science degree to disconnect the terminal. My fear is that I reconnect everything and all of a sudden there are new errors and faults, check engine lights etc that I didn't have before.
I did slightly pull down the headliner and can see the module. Is it simply a matter of getting a new module, unplugging the old one and swapping in the new one?
