Disconnect Battery to reset TPM
Old Oct 22, 2020 | 02:27 PM
CU_Roving's Avatar
Default Disconnect Battery to reset TPM
I have been experiencing intermittent TPM system faults for a couple of months but more recently the error message comes on everytime I start the truck and never turns off. Pep boys replaced two bad sensors and confirmed that all 5 (including the spare) are functioning & transmitting correctly but the warning won't go away. I have read that disconnecting the battery for 15 minutes will "hard reset" the system which would cause the sensors to re-stablish communication with the truck and possibly save me from having to replace the module.
Seems like there is nothing to lose by trying, but I wanted to see if there is anything LR-specific I need to know about disconnecting the battery. I am coming from a BMW that basically required a computer science degree to disconnect the terminal. My fear is that I reconnect everything and all of a sudden there are new errors and faults, check engine lights etc that I didn't have before.
Old Oct 22, 2020 | 06:01 PM
DakotaTravler's Avatar
Just wait two minutes after shutting down truck and closing doors. Its a timer system that puts things to "sleep". Technically its not required if you really are doing a hard reset, the issues is that if you disconnect too soon some settings files can corrupt.
Old Oct 22, 2020 | 07:41 PM
houm_wa's Avatar
I'd wait 15 min....some systems are more sensitive, especially if they are on the CANBUS. Stereo and NAV come to mind.
Old Oct 22, 2020 | 09:38 PM
On another note, it could just be a bad TPMS module, they tend to fail being located in the roof. Lots of heat up there and I think that makes em fail.
Old Oct 22, 2020 | 09:53 PM
CU_Roving's Avatar
I did slightly pull down the headliner and can see the module. Is it simply a matter of getting a new module, unplugging the old one and swapping in the new one?
Old Oct 22, 2020 | 09:55 PM
I believe so, I dont recall them being VIN locked. A new module will take a while to sync up to the sensors though, probably 20 miles of driving.
scottahend
LR2
Jan 4, 2022 10:53 AM
jackh
Sep 13, 2020 04:39 PM
djkronik57
Jan 21, 2020 12:13 PM
hshamamian
LR4
Jan 20, 2020 03:30 PM
loomy123
Jan 4, 2014 09:09 PM
