Do I need to bleed coolant system after replacing thermostat
Old Feb 19, 2016 | 08:26 PM
cmb6s's Avatar
Originally Posted by schwaggy
People here mocked me when I said I dropped $60 on the Falconworks brass bleeder T. Now I definitely realize I'm ok with that. I will never have to change it or carry a spare.
That to me is worth it over having to worry and carry a spare and swap it every several years regardless.
Lol! Just imagine what a brass bleeder T would cost if it was an official Land Rover part.
Old Feb 19, 2016 | 09:00 PM
schwaggy's Avatar
They would never make it out of brass - too much lost revenue on a $30 plastic POS.
Similar to the hard brittle plastic coolant return lines on a Disco. Are you kidding me? Weakest link in the engine bay for a critical coolant path.
LR engineers are a sick breed.
Old Feb 19, 2016 | 11:24 PM
houm_wa's Avatar
Schwaggy, would you please be so kind as to PM me the part no. and source for that part? Maybe I'll go that route, too...
Old Feb 19, 2016 | 11:29 PM
Joemamma1954's Avatar
Upgrade for silly plastic T fitting in hose for Land Rover LR3
Old Feb 19, 2016 | 11:33 PM
houm_wa's Avatar
Thanks...ordered!
Old Feb 20, 2016 | 12:17 PM
EstorilM's Avatar
Seriously go to any auto parts store and buy a brass 1/8" NPT tee, 2x 1/8" NPT hose barbs, and an 1/8" NPT plug. Takes 2 minutes to make and costs probably $6.
I made a tube with a 1/8 screw in the end that I hook up to a container and you can kinda "power bleed" it when you unscrew the plug. I had 10 min of air or neutral pressure in there till I did that.
Old Feb 20, 2016 | 01:33 PM
DavC's Avatar
Those who run the brass tubes: Does it leak at all? Only reason I keep the OEM bit is because it doesn't leak..
Old Feb 20, 2016 | 07:00 PM
EstorilM's Avatar
The one I made is working perfect - same fittings used in high pressure steam, water, fuel etc. nothing "to" leak really.
Old Feb 20, 2016 | 08:09 PM
DavC's Avatar
Hmm... do you have a photo handy?
Old Feb 22, 2016 | 11:10 PM
Zelatore's Avatar
I too did the home-built brass bleeder using basic hardware store parts. It's been going strong for a couple years now with no problems.
I've also seen one fail on the road. 2 years ago a fellow club member's wife lost one driving home on I80 from a weekend event. Luckily her husband was right behind her in his P38 and he jury rigged a temporary repair with a bic pen body as a get-home.
