door locks Need Help!!
Old Feb 6, 2012 | 08:08 PM
alti's Avatar
Question door locks Need Help!!
I need some help with a door lock issue? I have a 2006 lr3 the front and rear right doors are having a locking issue. They sound and act like thay are working. You are locked in on the inside except when all the other doors are locked you can open those two from the outside. if the car is off it will sound the alarm. Not sure what the problem might be.... any help would be great.
Alti
Old Feb 7, 2020 | 07:55 AM
drcable's Avatar
Default Passenger doors dont lock
I have the exact same issue. I just purchased the vehicle and the kids opened the doors and the alarm went off. Seems strange that it would be just the passenger side. Then i found out the rear door doesnt open from the inside. Checked the child lock and that was not it. Before i tear the doors apart i was hoping someone else had the same problem and would have a solution...
Alti
Old Feb 8, 2020 | 07:16 PM
DakotaTravler's Avatar
Well one thing you can try is double/triple locking. I have to triple lock mine to get the driver door to lock and even then sometimes it does not. All the rest of mine are fine, for now.
Here is a solution that requires no new parts, but watch the video to the end as his first complex fix fails and a simpler solution works better.
Old Feb 13, 2020 | 05:23 PM
VegasLR3's Avatar
Had same problem with my left passenger door. I bought a new locking module online (not from dealer) and did the R&R one Saturday and its still working after 3 years. Was looking into fixing it but everything inside is mostly plastic which will eventually break anyway so decided to replaced it with a new one.
Old Feb 15, 2020 | 04:51 AM
166cui's Avatar
3rd Gear
Hi there,
if you know how to turn the spanners you can safe yourself a bit of money and repair the door lock as a DIY job. The locks do fail because of dirt and grime inside the lock's actuator motor. So the idea is to remove the door lock assembly from the car and to dismantle it. Eventually you'll get to the electric motor and give it a good clean.
This way I got my rear passenger door lock working again and it's working ever since.
Here's the How-To: KLICK
Cheers, Alexander
USPSABM
Aug 22, 2017 01:19 PM
Disco__Stu
Jun 18, 2014 09:36 AM
alti
Feb 7, 2012 09:38 AM
danvlarsen
Mar 17, 2011 12:00 PM
AK Rover
Aug 15, 2008 04:37 PM
