Dreaded lower control arms
Old Jul 1, 2020 | 12:52 AM
Cjlr3's Avatar
Default Dreaded lower control arms
Finally getting around to replacing the front lower control arms on my LR3. I was getting the death wobble around 50 mph, the occasional clunk when braking, and poor wheel alignment.
I’m replacing them and am having a TON of trouble getting the new parts on. I’ve watched every walkthrough video I could find and read every relevant blog post here and elsewhere.
I’ve tried switching the order of when adding the new part into each of its connection points and after hours still no luck. When I do have the cam bolts in, the strut bolt doesn’t align. The vehicle was in access mode and had the battery pulled. Did anyone else encounter this kind of trouble? Thanks for any insight you can offer.
Old Jul 1, 2020 | 08:15 PM
DakotaTravler's Avatar
Deflate the bag, you can do so at the valve block. You can also do so at top of the strut but I find the valve block easier to access. Normally you would want to command the system to deflate all corners, but you need a GAP tool or laptop to do it.
Old Jul 2, 2020 | 01:42 AM
Cjlr3's Avatar
You are a wizard, sir. I had actually just finished doing exactly this (under front of front passenger wheel well) before seeing your reply, and it was the final bit needed. Woo doggies, that was some work.
archaeology_student
Aug 30, 2020 07:54 AM
LONERANGER7010
Apr 13, 2020 01:48 AM
Kushan Gunawardane
Feb 1, 2020 05:11 PM
Bdeleon
Sep 3, 2018 07:48 PM
BritCars
LR4
Oct 16, 2015 02:02 PM
