Driver side armrest repair options
Old Apr 9, 2018 | 07:30 PM
LR3P0's Avatar
Default Driver side armrest repair options
Apparently my armrest adjustment stop (see picture) broke off because now my armrest just flops around. So what suggestions would you recommend to fix it? Tig weld? drill it out and install a bolt? This stud is welded to the seat so its not an option to replace. I think the stud the armrest hangs on is hardended so not real sure about drilling through.
what say you forums experts?
Old Apr 10, 2018 | 09:17 AM
memphis_rover's Avatar
How is the condition of the rest of the seat? I see good looking used ones on eBay for around 200 quite a bit.
Old Apr 10, 2018 | 05:16 PM
LR3P0's Avatar
Its in great shape so, I had not considered replacing the whole seat. that might be the better option. I have the alpaca color so I will check it out..
Old Apr 10, 2018 | 07:32 PM
Geo's Avatar
Geo
I’ll have to look at mine. I removed the armrest a while back as the leather was in bad shape. I recall it being a large roll pin. Find a big roll pin and drill out the hole if needed.
Are you near Los Angeles? I may have a set of Alpaca seats.
Old Apr 10, 2018 | 08:30 PM
Geo's Avatar
Geo
Just verified....it’s a roll pin.
Outside diameter installed is 10mm and length is 30mm
Old Apr 10, 2018 | 09:15 PM
LR3P0's Avatar
Excellent, thanks Geo for the dimensions and picture. Im far away from LA. I live in Alabama. I will look into drilling it out and installing a roll pin.
lhoward47
LR2
Feb 28, 2024 01:08 PM
Broken08
Apr 7, 2022 04:50 AM
lhoward47
LR2
Jan 13, 2018 12:14 PM
Sattman69
Jul 16, 2015 06:38 AM
dylanjacobus
Aug 7, 2013 11:54 AM
