Drivers side climate control stays cold only
Can be a blend door for that side but it usually is the heater core. If it came on suddenly, it's mechanical. If it seems to have come on slowly over time its probably the heater core. A proper citric acid flush can sometimes help clean out the core. Also there is an HVAC self-test your can do (search) that might indicate if there is an issue. FYI these heater cores are always on, always flowing.
VikingDiesel
05-22-2009 07:34 PM
