driveshaft center bearing
Old Nov 29, 2015 | 09:26 PM
Zelatore's Avatar
Default driveshaft center bearing
Today I was under the truck with the skid plates off doing diff and transfer case oils. Since I could actually see the driveshaft I reached up and gave it a shove - and it moved a lot more than I expected up/down.
I can't actually see the center carrier unless I remove the the heat shields, but I'm wondering just how much movement is normal. I would think very little.
Before I tear into it, anybody have some input on this?
Old Nov 29, 2015 | 09:40 PM
TOM R's Avatar
Pull the shield, you may end up buying a drive shaft I did
Old Nov 29, 2015 | 11:28 PM
Zelatore's Avatar
what was the over-all failure you found on the driveshaft? I haven't seen any problems at the end joints, but I'm not ruling it out until I do a better inspection next weekend. Man, they are proud of those things at $500+ aren't they?
Old Nov 29, 2015 | 11:30 PM
Just a little movement. To much and you could wear a hole in your gas tank......
Old Nov 30, 2015 | 11:14 AM
Zelatore's Avatar
Hole in the gas tank you say? Well that would be a 'bad thing'.
One more thing to check on I suppose.
Old Nov 30, 2015 | 01:52 PM
abran's Avatar
I found an eBay seller selling the center carrier for the driveshaft, but I can't tell how you would replace it.
Any ideas?
Prop Drive Shaft Driveshaft Center Support Bearing Mount for Land Rover LR3 LR4 | eBay
Old Nov 30, 2015 | 08:33 PM
Zelatore's Avatar
I've seen the center carrier available in a few places, but not having looked at the driveshaft yet I don't have any idea how it's changed. I can only assume it's do-able since the part is sold separately.
Old Dec 1, 2015 | 01:21 AM
Zelatore's Avatar
I found a write-up on doing the center support on D-web. It doesn't look fun.
Given I've got one weekend before a big trip, I think I'll just order up one of the cheap aftermarket complete shafts for $351/free shipping. I'll call in the morning to make sure it's in-stock and will be here by the weekend.
Old Dec 1, 2015 | 08:56 AM
abran's Avatar
I used the search function in dweb and couldn't find it, also looked at every post back to 9/07' and didn't see it.
Do you have a link? It's not that I am cheap, but I do find it ridiculous to throw away a driveshaft because of a torn rubber piece.
Old Dec 1, 2015 | 09:35 AM
Zelatore's Avatar
crap....maybe it wasn't d-web? Of course I didn't save the link. I do know it was a british site and the thread was several years old, starting with 'can't be done' and finally ending with 'here's how I did it'.
I'll dig around again if I get the chance.
I agree with you about the replacement, but I'm going to be low on time and don't want to get caught at the last minute, so easier/safer to just replace the whole thing.
