EAS Control Module
#21
The voltage is based on height, for the front sensors, voltage and height are inversely related. So all the way down will be near 5v, and all the way up near 0v. It should not get to either 0 or 5v, as that would be it's absolute limit, and would mean the the sensor is physically installed wrong.
#23
Yeah, sorry for the confusion, I didn't make myself very clear above...
I meant on a normally working truck, without an issue, during a height sweep no sensor should hit it's limit. This would mean that the truck is able to be at a height that the sensor can not read, which is incorrect. Also note that the rear sensors are directly related to height, so voltage vs height is backwards of the front.
Good luck with getting this sorted out.
#24
Roverguy, You're dead on ***** accurate.
What Houm Wa has neglected to report in this thread is that he's running 32" tires.
See thread
https://landroverforums.com/forum/lr...eedback-58749/
I would guess he's got jonson rods or some other brand lifting rods installed.
You can not calibrate the EAS with these rods installed. period.
Install the factory rods, calibrate the EAS, Then install the lifting rods back onto the vehicle.
See thread
#25
Well that does change it up a little.
I would still go into the diagnostic interface to see what the RLM is seeing, and go from there. And yes, I have had to deal with 'lifted' trucks before, not the easiest thing to manage calibrating without swapping the sensor links out. Can be done, but I wouldn't trust someone that might not be able to clear the faults to figure it out. But since sensor feedback is linear, and if you know the amount of lift the new links are designed to give, you just need to subtract that value from the 'measured' height, but you will run into the big tires causing it to bottom out when it lowers down, and still not be able to calibrate. It gets a little complicated at that point.
#26
I don't know about me "neglecting" to include that fact, Mike G. This thread was a continuation from the one you linked. My apologies if that much wasn't clear. That said, I am not running any kind of rod-mod.
I have the GAP IIDTool and use that to raise the suspension electronically. The original settings were restored before the truck went to the dealer.
Good? As always, I appreciate everyone's help.
#27
#28
Dave, as far as the EAS knows it's completely stock. The vehicle has been completely lowered with these tires on (that's probably how the wiring loom got cut) and it just BARELY clears the tires.
Oh, and I know all about the sensor links. They are shorter (than stock) in fact. I used to use 'em but the IIDTool is better because it allows me to run at completely stock settings except when I'm actually on a trail.
#30
Yeah, my bad on the links, you're right...
The adaptive headlights can fault for a few different reasons, was this an issue before the EAS issues you had?
It requires calibration of the EAS system so that they can work properly. If it is showing the light, it will also be showing faults in the system, and that is where I would start with getting it taken care of.
There is also a headlamp calibration routine in SDD that can be done, and sometimes needs to be done after a ride height calibration.
