End of rear differential breather
Has anyone a picture or has found where the end of the rear differential breather tube is? Where do you access it?
The front is easy, just under the hood.
If the rear cap is anything like the fronts its got to be clogged. So I want to put a different type of cap on it.
I believe it terminates behind the gas filler assembly in that mess of tubing. It should go up, and run along the fuel tank fill line. It terminates behind the fuel fill assembly.
1 - Filler cap
2 - Bracket
3 - Screw M6
4 - Filler cap lanyard
5 - Charcoal canister breather hose
6 - Charcoal canister vent hose to atmosphere
7 - Charcoal canister (ROW)
8 - Rear differential breather pipe
9 - Tank breather pipe
10 - Clamp - filler hose
11 - Fuel filler pipe
12 - Screw M8
13 - Lower mounting bracket to EPB bracket
1 - Filler cap
2 - Bracket
3 - Screw M6
12 - Screw M8
Its a plastic hose that has a vent at the end. If the vent is plugged pressure will build up when it gets hot. The current vent of the front diff is junk. Tiny little filter that is pre clogged.
Here is a diagram showing what I described. Note the little hose sticking down in front of #5, this is the diff breather tube.
DISCO3.CO.UK Photo Gallery - Thread Uploads/fuelvents
