Engine coolant leak near oil engine/oil cooler
Old Mar 22, 2015 | 10:13 AM
Rufflyer's Avatar
Default Engine coolant leak near oil engine/oil cooler
I have been chasing a small coolant leak for more than a month. A casual inspection during an oil change I noticed a small amount of coolant between the engine block and the adapter that the oil cooler/filter attach.
Removal and replacement seem straight forward; just clamp the coolant hoses, remove the oil filter, unbolt the adapter from the engine block. I don,t know if coolant comes from the block here, but since it has two hoses I would guess nis, yet it appears to be leaking from there. ( see attached picture)
I know I will loose GALLONS of coolant if it does; I am prepared for that. What I cannot find is a part number for the gasket/O-ring or any other exotic method Land Rover may use to seal this part.
Any advice from a parts number guru here in the US or from our cousins across the pond would be helpful.
Attached Thumbnails Engine coolant leak near oil engine/oil cooler-0322150916.jpg
texdisco
Jul 6, 2015 08:34 PM
Beaulim
May 2, 2014 08:03 PM
wheelgarage
Dec 29, 2012 01:50 PM
javven
Jul 15, 2012 10:09 AM
