Engine Struggles on Cold Start Up
Old May 27, 2016 | 12:13 PM
djkronik57's Avatar
Default Engine Struggles on Cold Start Up
An issue I thought I resolved with a throttle body cleaning has recently started to come back: on cold starts, once the starter disengages, I can feel the engine really struggle to get up to normal RPMs. Last time I had this issue, it was so bad the starter kept cutting back in to help out. Seemed to go away with a throttle body cleaning about 6 months ago, but over the past few weeks it seems it has gradually come back. It seems to struggle for a couple seconds before it revs up and doesn't do it when warm.
Don't think the throttle can get that gunked up in only 6 months, can it? I cleaned it out pretty thoroughly, front and back of the plate. Only other thing I can think of is that the spark plugs are due for replacement soon (95k miles, they are likely original).
May or may not be related...my idle is a little lumpy and I've got a strange vibration at 1100 rpms that I haven't figured out yet.
No warnings or lights on the dash. Pulls strongly.
Old May 27, 2016 | 12:26 PM
cmb6s's Avatar
I would check for vacuum leaks first and clean your MAF sensor while you're at it.
Old May 27, 2016 | 03:36 PM
DavC's Avatar
>any codes?
>clean MAF
>check that engine air filter is not gunked up to hell
I did plugs at 103k they were fine, a bit dirty, minor valve cover leak but otherwise ok
Old May 27, 2016 | 07:44 PM
TOM R's Avatar
Clean the throttle body
dynomite
Feb 14, 2015 04:33 PM
snads
Dec 6, 2014 02:42 PM
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
blackwd
Freelander
Jan 4, 2010 03:47 PM
