Engine vibration on 6500 RPM - LR3 2005
Old Jul 13, 2015 | 02:11 AM
a_wick_2010's Avatar
Default Engine vibration on 6500 RPM - LR3 2005
Once I want to push the accelerator to the maximum
Here is the result
2005 LR3 LHD
Transmission - P (parking)
Press accelerator to maximum
Rather than 8000 RPM as per seen in dashboard, only around 6500-6700 RPM maximum can be achieved and engine start vibrate, is it normal?
If not what to do?
Thanks mate
Old Jul 13, 2015 | 09:58 AM
unseenone's Avatar
I do not believe it is a good idea to do that in Park. How is it under normal driving conditions... What let you do feel the need to do it while parked?
Old Jul 13, 2015 | 11:17 AM
drowssap's Avatar
Does an LR3 have a rev. limiter?
Old Jul 13, 2015 | 11:55 AM
Racer X's Avatar
It's normal, but really, you shouldn't be holding the engine against the rev limiter in Park. That's a good way to overheat some important things, like the torque converter for example.
Old Jul 13, 2015 | 04:12 PM
unseenone's Avatar
No, I do not believe there is a rev limiter, you can just blow it apart... but why would you want to do that?
Old Jul 13, 2015 | 10:35 PM
Racer X's Avatar
I'm positive that it has a rev limiter. Everything has a rev limiter.
My 1988 Pontiac (Daewoo) LeMans had a rev limiter at 6k, and that car was a complete piece of ****. My Taurus SHO has a rev limiter at 7250 RPM. My motorcycle has a rev limiter at 12k RPM.
The LR3 definitely has a rev limiter.
Old Jul 14, 2015 | 06:11 AM
Ghaniba's Avatar
Logic says it would have a rev limiter, but... Can't say I've ever tried, nor would I want to.
To the original post -- Yes, at over 6000 rpms, any v8 engine should have some vibrations, now knock it off.
Dave
Old Jul 16, 2015 | 04:16 AM
Thanks all for your feedback and seems conclusion it's normal. Your feedback is much appreciated
flyboy_iii
Nov 1, 2013 08:03 PM
Mnt_Engineer
Apr 20, 2011 05:53 AM
u20090103
Jan 22, 2009 05:58 PM
jasongilliland
Jan 24, 2006 12:45 AM
jasongilliland
Sep 8, 2005 10:18 PM
