Adjust Headlights for UK Import?
Old Jul 14, 2015 | 11:56 AM
the12vman's Avatar
4th Gear
Default Adjust Headlights for UK Import?
My 2008 LR3 is going 'home' in a few weeks (I have a job transfer to England). In order to pass their national auto inspection (MOT) the headlights need to be aimed toward the left ditch vs. right, as not to blind oncoming drivers.
Is there a way to switch or adjust the lights or am I looking a replacing the units? Thanks.
Dave
Old Jul 14, 2015 | 12:37 PM
Racer X's Avatar
Replacement, sadly. The DOT beam pattern is vastly different from ECE, let alone RHD ECE.
Old Jul 16, 2015 | 11:27 PM
bbyer's Avatar
Default What headlights do you have?
I note the remark about USA/DOT headlight patterns being different than EU patterns, and then of course the LH/RH side of the road driving.
That I would say would be true for the conventional tungsten filament lamps but not for the HID Xenon projector lamps.
The projector lamps have a lever within that changes the beam pattern from that which is required to drive in the UK to that which is required to drive on the Continent - ie, in the EU such as France, Germany, Italy etc.
The lever works both ways so a French D3 with the steering wheel on the USA side can take the car ferry and drive in the UK without blinding other UK drivers.
Note that the lever does not change the side the steering wheel is on.
This is a link re where the lever is.
DISCO3.CO.UK - View topic - HID Headlight Setting For France
The 7 page pdf link below has pictures but is for the D4 but it is similar for the D3.
DISCO4.COM - View topic - Changing head light direction!
Old Jul 17, 2015 | 01:40 PM
the12vman's Avatar
4th Gear
Thanks! --will give it a try. I still have to drive on the right for 10 more days, though, so I'll have to wait until next weekend.
thecarpe
Defender
13
May 19, 2011 12:22 PM
2k7997tt
Defender
17
Sep 26, 2009 10:05 AM
Street Wolf
Sep 27, 2008 08:58 AM
WI Rover
Defender
Apr 30, 2007 04:14 PM
dgd
May 31, 2005 03:35 PM
