EPB removal
EPB removal
Hello all,
I am having my left rear wheel heat up and drag, presumably the parking brake. I have read Bodsby brake bible about the adjustment. I have read about others removing the system all together. Does that involve just removing the shoes? What else is required? In the mean time until I can get in there an replace the shoes or remove it, can I just back the adjuster off all the way on that wheel so the shoes aren't in contact with the drum at all and drive that way?
Thanks,
Aaron
Thanks,
Aaron
delormea397 (11-03-2016)
Hello all,
Thanks,
Aaron
Thanks,
Aaron
Thanks for that info!
So those who remove the EPB system altogether, what are they removing? Obviously its not just the pads? Pads and actuator?
I never use the system and from what I read it seems to be quite a bugger to maintain. I know that mine had the actuator replaced a year ago, before I bought it. It's a system I could do without.
I just did this for a customer despite my advice not to do it.
His actuator was malfunctioning and even when it was not engaged it had pulled the driver side cable and even after backing the pads off all the way it was dragging.
He was adamant that he didn't want the parking brake so I took off the drum/disk removed all the components but even then the cable seemed like it my rub on something as it was not anchored, so I cut it off just after the frame hook.
no faults whatsoever.
delormea397 (11-04-2016)
I like to have my vehicle with all of the systems in working order. He and I both live in flat areas but on the off chance that he wants to park on Lombard street in SF, he would want a parking brake.
He lives in Nevada and I live in CA. In CA all you need to do is pass smog and you are on the road. If the car is salvaged and you want to bring it back to working order/register it, then you have to have a safety inspection.
I would like to have it in working order as well, but I'm not sure I can make that happen right now. Stupidly busy. I do not want to permanently disable it, but I need to make it safely drivable until university exams are over.
What about removing the brake shoes and just disabling the actuator? By say unplugging the harness or pulling a fuse? Is that a possibility? I may look at the wiring diagram and see if there is a fuse that only covers the actuator. I do not want to cut cables if I dont need to. I also do not want to drive it with dragging brakes and have the shoes delaminate and jam inside there as I have read happens.
