Every light is on the dash when cold
Old Dec 12, 2024 | 11:55 PM
CantComplain's Avatar
I bought my 2006 after an indie had done some charging system work, including an alternator and battery. The PO had to take it back and they replaced the alternator again. I then bought it and it had an overvoltage code (don't recall what it was, but I posted it and you could probably search and find it). IIRC, I was getting high 14's from my multimeter. Napa replaced it again (third time) and that time it stuck. It was this one: https://www.napaonline.com/en/p/RAY2136830 Even if you don't have the same one, I'd take it back. I did not have the same issue on the dash that your son has but I could see running it that high could cause issues like that, which will probably need to be addressed separately per all the above help.
Old Dec 13, 2024 | 09:34 AM
Perfectphoto's Avatar
It was the alternator and it's back at the shop that put it in for him. I got my figures crossed as that is the problem.
Old Dec 13, 2024 | 09:46 AM
DakotaTravler's Avatar
Yeah, lets see how it is after the swap. I have had bad luck with alternators also. I think it was my BMW that took three alternators to get a good working. The first rebuilt was bad upon install, the second failed within a couple weeks I think. Third lasted years. It is really frustrating. Now I have an LR OEM unit sitting on a shelf for next time. But if you keep the old ones, they are pretty easy to rebuild. I have a couple cores on hand for the day I finally get around to it.
Old Dec 13, 2024 | 12:12 PM
wirh the last one I returned (didn’t have the history on the first two), the alternator worked great at 15v. It think it was the regulator/rectifier that was the issue. If Napa hadn’t replaced the whole thing, I was tempted to replace that part only and see if that fixed it. I think it was like $30.
since the OP’s title is this only happens when cold (and more juice from the alternator?), hopefully the new one solves his issue
Tracecollier@yahoo.com
May 13, 2023 10:12 PM
flyer08
Jun 2, 2021 11:48 AM
fbreeden
Oct 23, 2015 08:29 PM
novavon
Oct 23, 2010 02:36 PM
kfordric
Mar 23, 2006 12:20 AM
