Failing smog test on 2005 LR3
The testing facility sounds like Captain Obvious stating that something has failed but they don't know what?
I'm so glad we don't have emissions testing here in Michigan. I know that I wouldn't pass the test.
Not much help, I know. Hopefully things will get better soon and someone will come along and point you in the right direction.
Good luck!
Good luck!
yeah, as mentioned your readiness monitors are not set. Any decent smog place checks that before testing your vehicle.
Clearing a code or disconnecting the battery will cause them to not be ready until you finish complete drive cycles. In CA all need to be ready except for the evap monitor to pass
Its your catalytic converter. I had the same issue.
